Old 01-01-2021, 02:33 PM   #1
Krylon32
Default 32 Ford door lock cylinder
I lost the contact information of the man who rebuilds and re keys 32 lock cylinders. He did a couple for me several years ago and they worked good. Can anyone help? I need another one done. Thanks
Krylon32 is offline   Reply With Quote
Old 01-01-2021, 02:37 PM   #2
Andy
Default Re: 32 Ford door lock cylinder
You may be looking for 32Phil
Andy is offline   Reply With Quote
Old 01-01-2021, 02:40 PM   #3
DavidG
DavidG's Avatar
Likely 32Phil of upstate New York. I highly recommend him, however he may have escaped to Florida for the winter.
Old 01-01-2021, 03:44 PM   #4
deuce lover
deuce lover's Avatar
You might have to wait until April unless you contact the other locksmith who is a member here.
Old 01-01-2021, 04:13 PM   #5
Krylon32
I'm in no hurry, I won't need the cylinder until early summer.
Old 01-01-2021, 07:36 PM   #6
Hal Beatty
Hal Beatty's Avatar
FlatHeadCoupe also does lock repairs...
Hal Beatty is offline   Reply With Quote
Old 01-01-2021, 07:43 PM   #7
OldGold360
Yep, Phil has escaped to Florida and will be back sometime in April.
OldGold360 is offline   Reply With Quote
Old 01-02-2021, 12:30 AM   #8
cas3
32 Phil has done some work for me also. even though he is down south, i'll bet he visits the barn occasionally, and a PM would get his attention to get the ball in motion.
Old 01-02-2021, 07:05 AM   #9
Terry,OH
Terry,OH's Avatar
Also a member here John McClure in N.C.
Old 01-02-2021, 08:08 AM   #10
mercurycyclone
32phil. 845-551-5132. Early Ford lock & Key Service
mercurycyclone is offline   Reply With Quote
Old 01-02-2021, 06:32 PM   #11
Hal Beatty
Hal Beatty's Avatar
John McClure "FlatHeadCoupe" did all the locks for my '40. Excellent work and had them back to me in a week...
Old 01-03-2021, 12:39 PM   #12
STEVE O
STEVE O's Avatar
2nd John McClure. Excellent work & reasonable
STEVE O is offline   Reply With Quote
Old 01-03-2021, 03:21 PM   #13
FlatHeadCoupe
FlatHeadCoupe's Avatar
Thanks for the compliments. Welcome all lock work/questions from '32 to '56.
Many handles, column drops, and lock assemblies in stock, all OEM, some NOS parts.
"cut-keys-to-code", but better to have lock in hand for tweaking.
Regards,
FlatHeadCoupe
FlatHeadCoupe is offline   Reply With Quote
Old 01-19-2021, 07:30 PM   #14
bmwillia
bmwillia's Avatar
I have a door lock cylinder that I need keyed to the ignition key. Anybody know how to disassemble the door lock cylinder on these old Fords?
Brad Williamson
bmwillia is offline   Reply With Quote
Old 01-19-2021, 07:55 PM   #15
TJ
TJ's Avatar
Unhappy Re: 32 Ford door lock cylinder
Usually if you look in the door jamb in the area where the lock enters the door you will spot a small hole in the jamb. In that hole you will spot a set screw. That screw holds the lock assembly in the door. Many times that screw has been in there for a long time so you need to use something like PB Blaster to soak it to try to get it loose. If the set screw has a slot for a regular screw driver be very careful not to put too much pressure when trying to loosen the screw. Once the set screw is backed out the lock assembly can be pulled out. If one side of the slot breaks off you are basically doomed to ever get the lock out.
Old 01-20-2021, 08:39 AM   #16
bmwillia
bmwillia's Avatar
Yes, I have the lock cylinder removed. My question was regarding the lock cylinder itself. I have seen that the later Ford lock cylinders have an easy to remove cover holding the pins and springs in and removing that cover and rearranging the pins allows one to rekey the lock.
The lock I have has a cover but I have no idea how to open it up. I only have one ignition key so I am hesitant to mail it off with the cylinder to have the cylinder rekeyed plus I like to attempt to do things myself if it is possible.
Brad Williamson
Old 01-20-2021, 08:54 AM   #17
Don Rogers
Don Rogers's Avatar
Does your lock cylinder have a code stamped on the side. It should have 2 letters followed by 3 numbers...FD123 for example. If you have that you can get a key cut with out too much trouble.
Don Rogers is offline   Reply With Quote
Old 01-20-2021, 09:01 AM   #18
bmwillia
bmwillia's Avatar
I didn't see one Don but I'll double check.
BTW.. I was born in Cape Girardeau and my car was my grandpa's and spent most of its life in Essex, MO.
Brad Williamson
Old 01-20-2021, 09:06 AM   #19
bmwillia
bmwillia's Avatar
Also... I Just realized I have kinda hijacked this thread. My apologies. I have PM'd Flatheadcoupe.
Brad Williamson
Old 01-20-2021, 12:47 PM   #20
32phil
Hi Guys
Thanks for the kind compliments.
I'm in Florida till April
I'll be glad to help when I get back.
I'm on the Barn at least once a day sooo
you can PM me or call my cell 845 551 5132
Stay safe and well
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
