Old 12-24-2020, 03:17 PM   #21
petehoovie
petehoovie's Avatar
Default Re: What to check on a 46 Mercury
Originally Posted by Doctor's Ford View Post
Can anybody decode these numbers on the firewall? Just sent to me by the seller. Do they confirm is Canadian?
Old 12-24-2020, 03:33 PM   #22
Doctor's Ford
Doctor's Ford's Avatar
The number stamped on the body is better seen in my computer.
It is 24G 21452. Is not the ID plate which I show in a separate picture. Meaning??
Doctor's Ford is offline   Reply With Quote
Old 12-24-2020, 03:43 PM   #23
Doctor's Ford
The ID plate is partially covered by an electrical component (fuses?). These are the numbers and letters that are visible, arranged in 4 separate lines:
ENGINE - 6D-2437 (the rest is covered, not visible)
TRIM - M-165 (the rest is covered, not visible)
PAINT - M - 39 (the rest is covered, not visible)
CODE - 12 (the rest is covered, not visible)
It is very weird that the ID plate is partially covered. You would think that is not where you want to attach some parts to.
I have not seen the word ENGINE in an ID plate before.
I am sure some of you can tell the meaning of these codes!
Old 12-24-2020, 04:41 PM   #24
oldford2
oldford2's Avatar
Did 46 Mercs have 8BA,s? Round front parking lights? How long has the speedometer been stuck at 100 mph?
oldford2 is offline   Reply With Quote
Old 12-24-2020, 05:35 PM   #25
petehoovie
petehoovie's Avatar
I'm thinking that this "electrical component" you refer to is a relay for the aftermarket accessory spot light the car is equipped with. Amateurish installation...
Old 12-24-2020, 06:16 PM   #26
Als48
I think I saw an overdrive handle on the lower left of the dash. Must have overdrive. That is a very good feature.
Al Hook
Als48 is offline   Reply With Quote
Old 12-24-2020, 06:33 PM   #27
Graeme / New Zealand
Graeme / New Zealand's Avatar
Nice car I like these "baby Mercs" out of Canada, something a bit different, a ford in "sunday best".
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 12-24-2020, 09:15 PM   #28
Doctor's Ford
[QUOTE=Doctor's Ford;1966392]The ID plate is partially covered by an electrical component (fuses?). These are the numbers and letters that are visible, arranged in 4 separate lines:
This is what I could identify so far:
https://www.ford-trucks.com/forums/1...fo-thread.html
I have confirmed that Canadian Ford/Mercury did place this type of ID plate.
ENGINE - 6D-2437:
6 = 1946;
D = type of engine and transmission, 239 cu displacrement. Other source states D = 114" wheelbase
2437 is the engine sequence number for that plant
PAINT - M 3989 is Ford/Mercury marroon
http://paintref.com/cgi-bin/colorcod...&model=Mercury
I can not find any information of the meaning of the TRIM and CODE lines are in the ID plate.
To me this is sufficient information to believe this car is mostly original.
Old 12-24-2020, 10:44 PM   #29
Charlie Stephens
Check the serial number on the frame and be sure it matches the title.
Charlie Stephens
Old 12-25-2020, 08:05 PM   #30
B-O-B
B-O-B's Avatar
That hood gap looks like it needs an alignment to me. Passenger side fender top has a dip in it.
B-O-B is offline   Reply With Quote
Old 12-25-2020, 09:40 PM   #31
Doctor's Ford
Good catch. I missed the fender dip but I saw the hood gap and asked for one more picture which confirms this problem. The seller knows nothing about the car, is a used car dealer. I learned that car was at an auction a year ago in Denver and highest bid was 7500 and did not sell. Some red flags I suppose.
Started examining the procedure for alignment of the hood and read previous posts by Kube for the 1940s and if this 46 is similar, it is a big deal that I won't be able to handle. May be that is why despite a fair restoration the hood was not fixed.
Old 12-26-2020, 09:43 AM   #32
big job
big job's Avatar
Very nice don't worry about the hood my head don't fit my neck either and I'm a 1946
and another rust thing is the pre 1949 '48 & back' has a way better survival rust rate
than 1949 and up which were all boxed up. rocker panels dogs legs fenders all have been
all bondo'd up by now.
big job is offline   Reply With Quote
Old 12-26-2020, 09:51 AM   #33
corvette8n
corvette8n's Avatar
https://shop.efv8.org/collections/fo...book-softbound
This book should help answer some of your questions. I came close to buying a ‘41 Mercury that was Mayfair Maroon, but paperwork was questionable so I passed, I like that color of the ‘48.
Old 12-26-2020, 12:44 PM   #34
swoopNZ
MEMBER EMERITUS
There are some reasonably priced USA 46-48 Mercury coupes out there.
They have a rear seat like the sedans but are more desirable.
That's what I would be looking for.
Sedans are fine but the coupes have the edge on looks. IMHO.
Your money - your choice.
swoopNZ is offline   Reply With Quote
Old 12-27-2020, 04:51 PM   #35
DavidG
DavidG's Avatar
Welcome back, Manuel. I hope that the Mercury works out for you and I pleased to learn that you still have your '33 four.
David
Old 12-29-2020, 06:24 PM   #36
rayfour
Default Re: What to check on a 46 Mercury?
You won't have to be concerned with Babbitt Bearings with this one....
I have the exact same car, stock. This looks good from what I can see. If you need pictures from me for comparison purposes email me at [email protected]
rayfour is offline   Reply With Quote
Old 12-29-2020, 07:12 PM   #37
fsacht
You have a Canadian Ford/Mercury 114"wheelbase. The dash plastic is correct and in very nice shape. Those pieces are in my judgement the parts that are hard to find in good shape. Post your question on the Early Ford V8 Club web site. Flatheads are their subject and there are still some old timers who can help you. The site has a Mercury forum but you'll get good information from the forum, both Ford and Mercury. Nice car there.
fsacht is offline   Reply With Quote
Old 01-02-2021, 11:40 AM   #38
baceves
baceves's Avatar
beautiful car. Interior and Exterior looks just like my 47 ford. great family car.
baceves is offline   Reply With Quote
