Old 12-23-2020, 09:40 PM   #5
JSeery
JSeery's Avatar
Default Re: a good headlight conversion ?
Your best bet is to clean up what you have for starters. Make use all the connections are clean and tight, especially the grounds. Adding additional grounds is a fairly cheap why to improve current flow.
