Old 12-14-2020, 07:30 PM   #14
Bored&Stroked
Bored&Stroked's Avatar
Default Re: 1932 V-8 original steel cam
Take one look at the core . . . and you'll now it is a steel billet and not cast . . . is immediately obvious. Also, all original 32 cores have a press-on timing gear. I use the later aluminum press-on gears - gives you infinite timing adjustments.
