Old 12-13-2020, 12:10 PM   #1
rockfla
rockfla's Avatar
Default Proper way to adjust brakes
Is there a service bulletin on how to or a proper sequence on how to adjust brakes?? 1939 Ford/Mercury
Old 12-13-2020, 12:41 PM   #2
marko39
Default Re: Proper way to adjust brakes
Get a copy of 1939 and 1940 engine & chassis repair manual. It is available from several venders and covers brake adjustment .
marko39 is offline   Reply With Quote
Old 12-13-2020, 12:50 PM   #3
19Fordy
19Fordy's Avatar
Here you go: Shows brake adjustment and E-brake adjustment. To maintain the 25 pound adjustment pressure on the brake pedal I place a clean towel and a clean piece of clean plywood against the front of the seat bottom and a bathroom scale wedged between the plywood and the brake pedal with a length of 2 x 4..
Last photo is to clarify brake shoe orientation difference between Lockheed and Bendix.
Old 12-13-2020, 02:11 PM   #4
rockfla
rockfla's Avatar
Thank you both!!!
