Old 12-11-2020, 05:05 AM   #1
Stoker280
Default Bolt sizes for pressure plate and bell housing
I am restoring a 1953 M250 classic (basically a 53 F250) with a 239 flat head and 4 speed transmission. I have the opportunity to get some hardware from a work site that is being closed. I was wondering if anyone knew the size and thread pitch of the clutch pressure plate bolts and the engine/transmission bell housing mounting bolts. Any of the hardware sizes would be great and I could take the opportunity to get some new fasteners.
Stoker280 is offline   Reply With Quote
Old 12-11-2020, 05:35 AM   #2
Mart
Mart's Avatar
Default Re: Bolt sizes for pressure plate and bell housing
Get them all.
The pressure plate bolts are 5/16 UNC (if the same as the earlier ones) and are about 1" long with a portion of plain shank. The thread is short it is not a standard bolt but you can shorten some longer ones.
I don't know about the bellhousing bolts but if the same as the earlier ones they are 3/8 UNC by about 1".
But seriously if they are going begging, get them all. You never know what you are going to need in the future.
Mart.
Old 12-11-2020, 06:15 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
Bell housing to engine bolts with cast housing are 7/16-14 x 1-1/4"
With pressed steel housing 7/16-14 x 1"
The pressure plate bolts are special 3/8-16 x 3/4" with appox. 5/16" that is not threaded.
Old 12-11-2020, 08:51 AM   #4
PeteVS
PeteVS's Avatar
For flywheel and / or pressure plate bolts, I'd recommend getting a set from ARP from any of the big speed parts vendors. They'll be the right size, proper shank diameter and "tougher than nails."
Old 12-11-2020, 09:20 AM   #5
G.M.
The non threaded area is for alighnment. G.M.
www.fordcollector.com
Old 12-11-2020, 08:00 PM   #6
Ol' Ron
Ol' Ron's Avatar
Be carful with the pressure plat bolts. A friend of mine ordered some and they were WRONG!! these bolts should have a shoulder on them that match the flywheel. Sometimes you get the wrong part???
Old 12-11-2020, 08:06 PM   #7
GB SISSON
GB SISSON's Avatar
That shoulder is very important.... And it could be same diameter as the unthreaded area of a regular bolt. But in a HD truck like an F250 in granny gear with a load, and dump the clutch heading uphill, think of the shear on those 6 rather small bolts!
Old 12-12-2020, 07:10 AM   #8
PeteVS
PeteVS's Avatar
Originally Posted by GB SISSON View Post
Think of the shear on those 6 rather small bolts!
Not too bad on the pressure plate bolts due to the large diameter of the bolt circle but the flywheel bolts see a lot of shear! And, half of the torque being applied to the clutch disc is coming from the flywheel direct, only the other half from the pressure plate.
