Old 11-11-2020, 03:36 PM   #1
First time restorer
Default Cracked steering column sleeve
The steering column sleeve on my 1939 Ford is cracked down near the steering box. Is this a major problem? Is there an easy fix short of removing the entire steering column. It grinds a little when you turn the wheel.
First time restorer is offline   Reply With Quote
Old 11-11-2020, 05:35 PM   #2
Terry,OH
Terry,OH's Avatar
Default Re: Cracked steering column sleeve
You may want to check out a Chassis parts book for the part your seeing as cracked. There is an upper bushing under the steering wheel, many replace with a bearing.
Old 11-11-2020, 07:02 PM   #3
GaryU.
GaryU.'s Avatar
I think there is a slot and a clamp at the bottom on the steering column where it attaches to the steering box. Perhaps your clamp is missing? Terry,OH probably has indicated the source of your grinding sounds, the upper bushing made of rubber, Here is a link to a drawing of the steering column and other parts from Mac Van Pelts site, lots of great info and parts. http://www.vanpeltsales.com/FH_web/F...ar_1937-39.jpg
GaryU. is offline   Reply With Quote
Old 11-11-2020, 09:11 PM   #4
JSeery
JSeery's Avatar
I'm not understanding this description, can you post a little more detail and maybe a photo?
Old 11-12-2020, 09:36 AM   #5
deuce_roadster
deuce_roadster's Avatar
I have seen 40 mast jackets broke off about 1 1/2 inches from the bottom and figured it was from collision damage. I didn't notice it until I removed the column as the broken piece was the exact length of the portion that slips over the steering box and the break was under the clamp. Seems odd but I have seen that. While I could have welded it up I just replaced the mast jacket as they are plentiful, I think 40-48 use the same one.
Old 11-12-2020, 10:12 AM   #6
skidmarks
skidmarks's Avatar
Ive have had the same thing happen. But mostly in trucks. Worn out suspension and loose bolt. Better check the bottom of your dash board at the column drop.
Only way to fix it is take it apart. It will be full of dirt and grease and if you dont clean it out good. Trying to weld it will turn into a bigger mess.
Once its clean its easy to weld back together
skidmarks is offline   Reply With Quote
