Old 11-08-2020, 04:19 AM   #1
miwi
miwi's Avatar
Default Camshaft for french flathead
I'm rebuild a 255cui french flathead. It will get 2 Strombergs and Edelbrock intake. A friend said I should install a new cam. Are there any recommendations which cam shaft can be used for a 255 French. Thanks
miwi is offline   Reply With Quote
Old 11-08-2020, 07:55 AM   #2
KiWinUS
KiWinUS's Avatar
Default Re: Camshaft for french flathead
I do not believe it matters that it is a French flathead as to what cam you use. You first need to decide what distributor you want to run. After that it’s your choice. You will get many opinions. I have sold many of my KiWi-L100 cams than have been installed in French flatheads. Enjoy your flathead. Cheers
Tony
KiWinUS is online now   Reply With Quote
Old 11-08-2020, 08:25 AM   #3
Ol' Ron
Ol' Ron's Avatar
Adding dual carbs, eliminates the stock distributor, so you'll need to change distributors anyway. AS for the grind, that's up to the application. but the cost will be high in any case. Gramps.
Old 11-08-2020, 09:44 AM   #4
Bored&Stroked
Bored&Stroked's Avatar
What type of distributor do you currently have and what is the overall amount of rework that has been done to the engine and what is the application (car, weight, transmission, gearing, how you drive it, etc.).
There is noting wrong with a stock cam for many applications (will have the best low-end power), but if you want more of a hotrod sound, then there are many choices - all depending on the application, the money you have to spend on new parts and changes, how the front of the engine is setup (front or side-mount distributor), the car it is in, etc..
Old 11-08-2020, 10:52 AM   #5
tubman
tubman's Avatar
We do need more information. If your avatar is the vehicle you are going to be using, your friend is probably wrong; if you're building a light roadster, he's probably right.
Old 11-09-2020, 02:07 PM   #6
miwi
miwi's Avatar
I'll use either a of Bubbas distributor or a Petronix. II want to use it in my '52 F1 that is nearly stock. I want just a bit more power so that I can keep up
better on the german Autobahn.
Old 11-09-2020, 02:53 PM   #7
tubman
tubman's Avatar
A couple of remarks. First, keeping up on the Autobahn may be more of an issue with the rear end gears rather than the engine. See this thread : https://www.fordbarn.com/forum/showthread.php?t=288337. Second, the cheapest and easiest way to get more performance out of a flathead Ford is to rework the heads for increased compression and optimum quench. It has been covered here and on the H.A.M.B. many times.
