Old 10-26-2020, 11:37 AM   #41
Hal Beatty
Hal Beatty's Avatar
Default Re: 1940 Brake Bleeding
I'll second what Talkwrench said... I installed a set of speed bleeders on my 40 and they worked great! Took about 10 mins. to get the brakes bled, and not having to listen to the wife, girlfriend or daughter bitch about having to pump the pedal was priceless.
Hal Beatty is offline   Reply With Quote
Old 10-26-2020, 12:28 PM   #42
tubman
tubman's Avatar
You got both? You lucky dog!
Old 10-26-2020, 01:41 PM   #43
JSeery
JSeery's Avatar
I always considered brake bleeding a social event!!!
Old 10-26-2020, 02:54 PM   #44
V8COOPMAN
V8COOPMAN's Avatar
But don't forget "social distancing"......6 ft. and the mask! Bleed-on! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-26-2020, 05:23 PM   #45
JSeery
JSeery's Avatar
Drivers seat to wheel cylinders should do it.
Old 10-26-2020, 06:53 PM   #46
51 MERC-CT
51 MERC-CT's Avatar
Bought these a couple of weeks ago, think they are capitalizing on current events.
Old 10-26-2020, 06:54 PM   #47
JSeery
JSeery's Avatar
I've never had the pleasure of working with non-US brake parts, but from the post here on the Barn it appears they can have multiple issues.
Old 10-27-2020, 02:39 PM   #48
Hal Beatty
Hal Beatty's Avatar
Not at the same time... I always knew better than that
Old 10-27-2020, 04:10 PM   #49
fordwife
I'm surprised no one has mentioned using a pressure bleeder. If you can borrow or rent one, that is the best way in my opinon.
fordwife is offline   Reply With Quote
Old 11-01-2020, 08:31 AM   #50
mike42
mike42's Avatar
There is a God ! First.....he invented Jack Daniels.........second I’m finally getting some pedal pressure after starting at rear wheel, but then I went to the front right. No leaks, but some pressure. Ordered new rears from C&G and will be here Monday.
Getting 3” of snow here today so I may not be able to start on the rears.
Thx all......Mike
mike42 is offline   Reply With Quote
Old 11-01-2020, 01:27 PM   #51
1931 flamingo
1931 flamingo's Avatar
RIGHT rear, LEFT rear, LEFT front, RIGHT front. JMO
Paul in CT
Old 11-01-2020, 02:23 PM   #52
JSeery
JSeery's Avatar
Thx all......Mike
Sounds like progress, but something is still not correct. Bleeding brakes should not be that big a deal at all.
Old 11-01-2020, 03:08 PM   #53
FortyNiner
FortyNiner's Avatar
It shouldn't but some of the struggles are familiar. Without speed bleeders I messed around for weeks.
Old 11-01-2020, 04:51 PM   #54
19Fordy
19Fordy's Avatar
Originally Posted by 1931 flamingo View Post
right rear, left rear, left front, right front. Jmo
paul in ct
Nope! RR, LR, RF, LF
Probably just a typo.
Old 11-01-2020, 06:38 PM   #55
Max
Thats not how we do it "Down Under"
Max is offline   Reply With Quote
Old 11-01-2020, 06:46 PM   #56
glennpm
glennpm's Avatar
Start with wheel cylinder farthest away from the master cylinder and end at the closest.
Old 11-01-2020, 08:07 PM   #57
V8COOPMAN
V8COOPMAN's Avatar
Is this how y'all do it "Down Under"? DD
T5 W/TORQUE TUBE
Old 11-01-2020, 09:07 PM   #58
19Fordy
19Fordy's Avatar
I think it would help future generations if we again taught auto mechanics in our high school shop classes. All this "needless bleeding" would stop.
Old 11-01-2020, 09:38 PM   #59
Talkwrench
Talkwrench's Avatar
Damn that would make it so much easier!
Old 11-02-2020, 05:00 AM   #60
mike42
mike42's Avatar
You guys are beautiful !! LOL
The only reason I went from right rear to right front is that I already had jack stands set up on both. Too lazy to take jack stand down and use at left rear. Plus it was 25º out yesterday with 45 mph wind gusts !!
We got 4" of snow yesterday and we're now going to be in the 50's and 60's later this week. Unreal and stupid, but...that's Michigan weather. I'll be back at it again this week some more.
I know this shouldn't be this tough to do, but when you've never done it before it's not all that easy.
Thx all....Mike
