I measured the exhaust valve lift with a dial indicator this morning.
I have .410 lift at that valve. That's a lot. Checked flathead cam specifications and found the aftermarket cam with .400 Isky Jr Going to try two washers this morning. Wish me luck This is why you should check A camshaft. |
