Old 10-24-2020, 02:47 PM   #2
drolston
drolston's Avatar
Default Re: A-team performance distributor issues
That is a complicated distributor, with both mechanical and vacuum advance, plus an array of springs and bushings to tailor the advance curve. It needs to be set up by an expert on a machine, with some knowledge of the cam.
That said, stumble at steady high rpm does not sound like distributor advance or timing. unless it is a week off. Could be coil, plugs, or ignition cables, but more likely a carburetor/fuel problem.
