10-18-2020, 08:15 PM | #1 |
Chassis painting
Does anyone out there know if the chassis parts were painted before assembly individually or, for example, was the rear axle assembly painted after assemble?
Thank you in advance for your input!! |
10-18-2020, 09:09 PM | #2 |
Re: Chassis painting
Some were painted before assembly and some, such as the rear end, were painted after assembly. We're talking many different components with many different finishes on the chassis.
10-20-2020, 10:09 AM | #3 |
Painting was done to all painted parts before installing them onto the frame.
Bob Bidonde |
10-20-2020, 08:15 PM | #4 |
How do you guys know this stuff!!??
10-20-2020, 09:59 PM | #5 |
Was the frame dipped or sprayed?
10-20-2020, 10:33 PM | #6 |
10-21-2020, 10:11 AM | #7 |
For me, I have spent nearly a lifetime of studying this. The Corvette and the Ford Model-A are the two most documented vintage vehicles ever produced. When the original factory prints, along with engineering notes and foreman's logs are studied, much of this is documented there. To make life easier for hobbyists, the national Model-A clubs have printed literature that offers this information to the restorer.
. . It was sprayed with a bituminous asphaltum-based coating. As it was handled, the soft thin tar-like coating was often scratched so Ford authorized those scratches and bare areas where riveting was done to be spot painted with Pyroxilyn during assemblage. . . |
10-21-2020, 11:33 AM | #8 |
I use gloss black Rustoleum enamel . While its not necessary , I add hardener for appearance and durability .
10-21-2020, 03:03 PM | #9 |
Right On Terry...
10-21-2020, 03:34 PM | #10 |
With all due respect what will you do with this information ?
10-22-2020, 12:39 AM | #11 |
I imagine it's similar to asking "shall I assemble my rearend and then paint it or paint the parts individually and then assemble?"
Makes a big difference in my mind as one would result in the entire rearend being painted black and the second what we would call "detailed" with the painted components black and the hardware, etc. a different finish. Just a thought. |
10-22-2020, 10:52 AM | #12 | |
10-22-2020, 11:52 AM | #13 | ||
I think it often falls in alignment with C.S, Lewis' quote about doing the right thing when no one is looking. Actually, I think it really boils down to what is happening to the hobby as a whole. Somewhere along the way, the mindset has changed from 'Restoring' (returning something exactly as it was in a previous timeframe) to a mindset of 'It is my car and I will do it however I want.'. It is never wrong to do the right thing, ...and generally it is considered 'right' when all of the bolts are reinstalled, when the paint colors are authentic, and .... |
