Old 10-16-2020, 11:53 AM   #1
toms32
Default connector sleeve for choke rod
Hi Guys ! I got the surprise of my life when I pulled on the choke for my 36 the the handle came off in my hand. When I looked underneath the dash I observed that the prior owner had used tape to keep the two rods together, I purchased the choke throttle connector sleeve from a ford parts dealer but in looking it over I can not see how the two pieces are held together with this piece. Can some one out there tell or show me how they solved this issue thanks tom
toms32 is offline   Reply With Quote
Old 10-16-2020, 12:31 PM   #2
Viv W
Default Re: connector sleeve for choke rod
Hi Tom
I think in the factory the dashboard rubber grommet was fitted on the knob end and then that sleeve was crimped into place.
I also could not figure how to crimp it back together with a new sleeve, so in the end I drilled a hole thru the sleeve and the rod and have fitted it together with split pins about half the diameter of the choke rod. It works a treat.
Viv.
Viv W is offline   Reply With Quote
Old 10-16-2020, 12:32 PM   #3
toms32
Many thanks Viv for the assistance Tom
Old 10-16-2020, 12:37 PM   #4
feufeu
feufeu's Avatar
Hi Tom, in my 37 there is a piece connecting the two parts of the rod. You can see it in the red circles on the picture (picture under dash).
Sorry for my english, i'm french!
I couldnt disassemble these rod but seems to be screwed...
feufeu is offline   Reply With Quote
Old 10-16-2020, 12:41 PM   #5
feufeu
feufeu's Avatar
...or crimped as said Viv
Old 10-16-2020, 12:42 PM   #6
Don Rogers
Don Rogers's Avatar
The rod pieces were originally crimped together using the metal collar. If you can't do that, then JB Weld them together using the collar
Don Rogers is offline   Reply With Quote
Old 10-16-2020, 12:53 PM   #7
tubman
tubman's Avatar
On a '36 I had years ago, they were soldered together. I heated them up with a big soldering iron and they came right apart. When it was time to put them back together, I used the same big iron to sweat them back together.
I'm not saying it's right; perhaps it was some former owners backyard repair, but I thought I'd pass on my experience.
Old 10-16-2020, 01:50 PM   #8
Don
Don's Avatar
Drill and tap a set screw in sleeve!!
DON P
Don is offline   Reply With Quote
Old 10-16-2020, 02:23 PM   #9
Tom-MI
Tom-MI's Avatar
What I did on my '35 was to thread the knob shaft and the connecting rod. Couple the two pieces together (the connector is a common hardware item). This allows you to align the knob writing, make an exact length and easy removal if needed.
Tom
Tom-MI is offline   Reply With Quote
Old 10-16-2020, 02:36 PM   #10
rockfla
rockfla's Avatar
It's amazing how these can be such a pain in the ASS. I STILL haven't found anyone that can tell me how to affix the "choke knob" back onto the choke cable on my 39 Mercury. Didn't find much more luck with the same issue on my 32!!!! WHY the repro's aren't made to "somehow" work on stock applications without a minor in mechanical engineering!!!
Old 10-16-2020, 04:30 PM   #11
oldford2
oldford2's Avatar
That is how I did mine
John
oldford2 is offline   Reply With Quote
Old 10-16-2020, 07:16 PM   #12
FlatheadTed
FlatheadTed's Avatar
Go to a electrical shop get a large 1/8 Nickel , plastic covered wire joiner it has two set screws in it x 2 ,Not stock but ,!
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 10-16-2020, 08:09 PM   #13
oldford2
oldford2's Avatar
Is it flexible like the rubber connector or is it straight? Straight won't work. the joint has to flex with the engine movement. Do you have a picture of it?
John
Old 10-16-2020, 09:38 PM   #14
DavidG
DavidG's Avatar
I deliberately take them apart to have the non-knob portion re-cadmium plated and use the original connecting sleeve and if I can't get a tight enough crimp, I use JB Weld as Don recommends.
Old 10-16-2020, 10:18 PM   #15
Rustyspokes
Rustyspokes's Avatar
Thumbs up Re: connector sleeve for choke rod
My fix was , went to a Shop for Nuts & Bolts, Got a long sleeve that was a 10/24 thread , threaded the Two Rod ends with a 10/24 Die (Carb end and the Dash Knob end) ,you can adjust the proper Rod lengths by turning the Threaded sleeve, then attach to the Carb.
Rustyspokes is offline   Reply With Quote
Old 10-17-2020, 08:27 AM   #16
glennpm
glennpm's Avatar
I did the same as RustySpokes
Old 10-17-2020, 09:46 AM   #17
joe 1950
joe 1950's Avatar
And that ends the lesson for today class. the Barn with out a doubt has to be the best place for old ford education great old american ingenuity
joe 1950 is offline   Reply With Quote
