Hi Tom
I think in the factory the dashboard rubber grommet was fitted on the knob end and then that sleeve was crimped into place. I also could not figure how to crimp it back together with a new sleeve, so in the end I drilled a hole thru the sleeve and the rod and have fitted it together with split pins about half the diameter of the choke rod. It works a treat. Viv. |
