I'm in the process of converting my 37 model 78 slantback from a 6v positive system to a 12v negative system with an alternator. i looking for advice on which spark plugs and coil to use. I'll continue to use the original distributor which has been rebuilt by Skip Haney.
Thank you for any advice in advance. Stay safe and stay healthy. John |
Check out vintageautogarage.com. They should have all the info and parts you need.
Brad Williamson |
send an original coil to skip and have it converted to 12v neg ground. autolite 216 plugs gapped at 030
Another of my wondering's why. I have been accused of going to 12vts by my friends,
nope 6vts pos grd. just bump the button its running. so we need these radios and other foolish stuff. I put a 12 volt garden tractor batt. in the trunk ran the wires under the seat floor mats to run a radio glove compartment. These electronics today use very little juice. Now charge phones listen to tunes plus a scanner. Maybe almost a year before I put the trickle charger on the battery . Also a plus, a solonoid from this 12vt to the 6vt. with a button I can jump the 6vt battery if dead..My feed is 10 gauge wire in witch only used for a moment.. |
#5 | |
#6 | |
Just saw this and glad I swallowed my tea first.
