Old 10-09-2020, 06:14 AM   #1
billybronco1
Default 36 Can't Stop The Oil Pan Drain Plug Drip
What gasket do you find is best on the oil pan drain plug? I have replaced the drain plug and can not stop the constant drip. I see Mac's has two types of washers, the crush type and the standard flat copper ones.
billybronco1 is offline   Reply With Quote
Old 10-09-2020, 06:53 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 36 Can't Stop The Oil Pan Drain Plug Drip
Don't be afraid to use some non-hardening Permatex along with whatever washer you choose to use.
Old 10-09-2020, 07:31 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
On some modern cars washers with rubber insert are used, I have used those washers on other problem leak cars
Kurt in NJ is online now   Reply With Quote
Old 10-09-2020, 08:17 AM   #4
Jacques1960
Jacques1960's Avatar
At your next oil change, take a moment to determine whether the threads of the drain are damaged or whether the surface to which the washer seals is not smooth; either is easily corrected and should assist with a permanent fix. In the interim, +1 on the Permatex option.
No job’s done ‘til it’s all done
Jacques1960 is offline   Reply With Quote
Old 10-09-2020, 08:22 AM   #5
Ron Pilger
Ron Pilger's Avatar
Suspected partial cross-threading at some point in the car's long run of life
Ron Pilger is offline   Reply With Quote
Old 10-09-2020, 09:44 AM   #6
RalphG
RalphG's Avatar
Teflon tape is a popular hydraulic thread sealant here and I've used it on oil pan plugs before.
RalphG is offline   Reply With Quote
Old 10-09-2020, 12:08 PM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
I'm not too sure I would want to use Teflon tape on oil fittings, plugs, etc It's not inconceivable that pieces of that tape might get inside the oil pan, and get pulled into the oil flow system, causing some blockage in small passageways. I know it's a no no on gasoline/fuel supply lines.
I would do as suggest by someone else here, check for cross threading of plug & oil pan threads, look for other possible damage of plug and pan in the sealing areas, and find or make a copper gasket that will stay on the plug when it's removed from pan
John
Old 10-09-2020, 12:43 PM   #8
swedishsteel
My 36 marks it's territory under the drain plug as well. In my case it isn't the plug--the bung itself leaks from the seam where it is attached to the oil pan. It is on my project list to take the pan off some day and put some JB Weld on the inside, but it will be done tomorrow..........and we know tomorrow is never here!!
swedishsteel is offline   Reply With Quote
Old 10-09-2020, 02:40 PM   #9
Jeff/Illinois
Jeff/Illinois's Avatar
I think after taking off that pan, if it was me, I'd get it brazed.
I'm not a big fan of JB Weld never had very good luck with that stuff.
Old 10-09-2020, 04:14 PM   #10
billybronco1
Thanks guys, I will take a closer look next time and will use some Permatex. So no comments on what washer to use? Anything one is as good as the other?
Old 10-09-2020, 06:53 PM   #11
paul2748
paul2748's Avatar
Have you tried a plastic washer backed up with a steel one?
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-09-2020, 07:05 PM   #12
billybronco1
Have not tried a plastic washer.
Old 10-09-2020, 07:06 PM   #13
whizzernick
whizzernick's Avatar
have you thought the leak might come from the large cotter pin in rear of pan ?
whizzernick is offline   Reply With Quote
Old 10-09-2020, 07:13 PM   #14
oldford2
oldford2's Avatar
I use a large rubber O ring. Works great
oldford2 is offline   Reply With Quote
Old 10-09-2020, 07:13 PM   #15
billybronco1
I have read about the cotter pin, have not investigated yet, need to really study under there next time my body feels like crawling under.
Old 10-09-2020, 07:17 PM   #16
billybronco1
Interesting idea, I suppose you need to be real careful not to over tighten the plug. Do use any other washer with the o-ring or just the o-ring? I have plenty of those.
Old 10-09-2020, 08:39 PM   #17
Zeke3
Zeke3's Avatar
I am not a fan of using an O ring in a joint that is not designed for it. I would use a copper or aluminum washer and replace it every oil change.
Zeke3 is offline   Reply With Quote
Old 10-10-2020, 12:46 AM   #18
aussie merc
aussie merc's Avatar
pipe tape was suggested by someone i to don't like tape for same reasons however i do use the liquid Teflon paste Wipe some on the thread small bead on the washer tighten and wipe off excess works a treat
aussie merc is offline   Reply With Quote
Old 10-10-2020, 05:55 AM   #19
fortyfords
fortyfords's Avatar
Have your machinist buddy turn out a thin aluminum washer for you or use my favorite thread sealer: Blue Monster, great stuff on anything but wash the area with alcohol first.
fortyfords is offline   Reply With Quote
Old 10-10-2020, 08:27 AM   #20
Norris McCarty
Norris McCarty's Avatar
A little Loctite 518 on between the washer and the pan will stop the leak and it’ll still be easy to remove.
Norris McCarty is offline   Reply With Quote
