10-07-2020, 06:37 PM | #1 |
Nor Cal Crank Grinder??
Is there any one in the Sacramento area that can grind a model B crank? Other nor cal shops?
10-07-2020, 08:24 PM | #2 |
Re: Nor Cal Crank Grinder??
Ask Turlock Machine Shop were they have their crankshafts done.
They are a Model A motor rebuild shop. Joe Silvils 209 495-1689. |
10-07-2020, 09:43 PM | #3 |
Thanks
10-08-2020, 03:31 PM | #4 |
Give Les Andrew a call also, He's close by and has someone close to him do a lot of work for him. 530 268 3018
10-09-2020, 12:58 AM | #5 |
Either Motor Warehouse in Sacramento, they usually just deal wholesale and not to the general public though.
Or my favorite is Bailey Bros. In American Canyon. They can really turn a crank. Not The cheapest but very good and understand the ins and outs of older crankshafts. I have them grind and straighten all the Model A and B cranks that I weld counter weights onto. They have also done a lot of work for Stan Vermeil over the years. |
10-10-2020, 11:53 AM | #6 |
Connoisseur of Rust |
10-10-2020, 02:08 PM | #7 |
Be advised that some B cranks have counter weights that over-lap the journal. They must be removed before grinding. When you call shops, you should be able to tell them what you have.
