Old 10-05-2020, 05:07 PM   #4
Pandersen33
Pandersen33's Avatar
Default Re: 1935 coupe-transmission removal
Ive taken it out the inside several times now. Actually pretty quick if everything goes the way it should. Maybe 2 hours or so. If you pulled the tranny mount off and obviously the shift tower im sure you could pull it out the bottom.
Pandersen33 is offline   Reply With Quote
