Old 09-09-2020, 01:44 PM   #11
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Title goes with Frame or Engine?
Originally Posted by dean from bozeman View Post
Brent, the Instruction Booklet would say this because when the car was new the engine number= the chassis number = the vehicle's title number.
The 'engine and title are to remain together' is wishful thinking, if that. And as I said before, that we mean that we have to retitle the vehicle every time an engine is swapped out. That isn't going to happen.
Dean, you are approaching this from a logical standpoint however not a lawful standpoint. The manufacturer stated the VIN for the vehicle would be the engine number. Ford had a protocol when engines were replaced where the mechanic was required to stamp the replacement engine with correct VIN. A Ford Agency was authorized to do this, -and they even warned in the Service Bulletins about outside individuals doing this re-stamping.
So the bottom-line in this is, the Title VIN does not get changed every time an engine is replaced, ...the replacement engine number does. Just because someone failed to correctly re-stamp an engine during replacement does not mean the law should provide an exemption for them. The engine number IS the correct VIN.
Yes Chris, this is a valid question coming from someone who called me asking what the correct info.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
