Old 09-06-2020, 09:07 PM   #10
flatjack9
flatjack9's Avatar
Default Re: 1939 pickup new distributor
Originally Posted by Talkwrench View Post
I have run that unit for about 8 years now almost daily [12 volt] , never an issue. The only thing I did do was make sure you loctite the screw that holds the 'button" on. Use the matching coil for it. I always thought the timing was really good on mine.
Have you ever measured the advance curve?
