Old 07-30-2020, 07:10 PM   #1
1947 ford
Default 8 ba
I have a question for the flathead gurue's , I have a 8ba motor with made in Canada on the heads , has aluminum intake 2 bbl. with 4 bolts, CC 9425 on the manifold, pulled 1 head, 4 inch stroke bored 3.250 with the pistons marked .040 , the motor turns over freely , has been converted to 12 volt coil and alternator . Has 3 speed trans attached , column shift . Valves all look good and marked ford script , see no visable cracks . What is this and how many cubic inches, and value , was going to use in my 40 ford but changed directions.
1947 ford is offline   Reply With Quote
Old 07-30-2020, 09:49 PM   #2
GB SISSON
GB SISSON's Avatar
Default Re: 8 ba
I think you are supposed to put this in the swap meet section. With a standard bore it would be 255 cu in. Now maybe 265-270? Anyhow you should list it in the swap meet with some photos. It will sell.
Old 07-31-2020, 06:32 AM   #3
Ol' Ron
Ol' Ron's Avatar
Default Re: 8 ba
260 cubes, interesting intake. However without a good block the value is questionable. Sometimes known as "A pig in a Poke"
Old 07-31-2020, 07:42 AM   #4
51504bat
51504bat's Avatar
Default Re: 8 ba
The 4 inch crank has value, again if its good. Always a crap shoot with flatheads.
Old 07-31-2020, 03:09 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 8 ba
Originally Posted by 1947 ford View Post
4 inch stroke bored 3.250 with the pistons marked .040.
We sorta have an oxymoron here. You say you have a 3.25" bore, yet a 0.040" overbore equals an actual bore of 3.227". Is it possible you mis-measured that 3.25" by a few thousandths? Nevertheless, if the bore is 3.227", the displacement computes-out to 261.72 cu. in. Now if the bore is actually 3.25", that computes to 265.46 cubic inches. DD
Click Links Below __
T5 W/TORQUE TUBE
