Old 07-25-2020, 03:41 PM   #11
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Wheel stands
Originally Posted by frnkeore View Post
. At one of the 3 shops I worked at, we had a much larger lift. It was about 3.5 ft wide and had a single ~12" cylinder and arms, hinged near the cyl, at least 4.5 feet long. It would lift, close to 5 ft. I liked it a lot! You would place it under the A arms or a cross member. You lifted the car, until the rear bumper, hit the ground (and then some). You place jack stands at the rear of the frame and then lowered it down on to the front stands. All 4 up in one lift.
Yep, They were called a 'Bay Lift'. Used them often years ago and wish they were still making them.
