Old 07-25-2020, 12:03 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Decided to pull the motor/trans
Valve guides in any engine will not cause that much oil consumption. Ringing it properly is a good thing. But, with .008" taper I would recommend sending it out for boring. I prefer to leave the piston clearances a bit on the wide/loose side. But, thats just me.
