#17 | |
the original ones work. I use 12 volt Pollock fuel shift valve that is made for trucks with dual fuel tanks. As I described I shifts by pushing a button and pushing the clutch. The 12 valve works on 6 volts. Pollock calls this a 6 port shifting valve. G.M.
www.fordcollector.com Last edited by G.M.; 07-21-2020 at 11:59 AM. |
