Hi,
I am building a A Speedster. I use all Gauges with the same design . Now I need the signal for the electronic speedometer. Does anymode have a solution? I think, the only way is the position at the torqueTube, where the original cable driven speedometer is connected. Here I can get the signal from a rotating cable or Pin and transfee it to a electronic signal. Does anybody has a drawing of such a solution? Thanks for help Willi |
Speedhut Gauges. has a speed sensor that screws directly onto the “turtle” and drives the electronic speedometer.
The speedo that they sell is calibraitable, and very slim body. Works great in the A dash panel. Only available in 12v, neg ground Been using them for years. Ken |
Followup:
speedhut # G-SNDR-11 Listed as a GM/Chrysler style, mag pulse. $50.85 |
Great answer!
Thanks a lot Willi Willi |
Speedhut has a GPS speedometer also if interested in that. I have a Speedhut 2" 4000 RPM tach. Last edited by Y-Blockhead; 07-01-2020 at 12:47 PM. |
