Old 06-17-2020, 09:47 PM   #13
35fordtn
35fordtn's Avatar
Default Re: LB block repairable (or can it be)?????
Originally Posted by Lawson Cox View Post
What is so all-fired desirable about LB blocks. A good babbit job is going to last you as long as you live and is a lot less expensive. If you're all that obsessed about an LB block, get some letter punches and stamp them on the block. Gimme a break.
I disagree, A set of Main bearings is $160 A babbit job will cost MUCH more than that. Aside from that cost, I would use either with no hesitation...
