Old 06-11-2020, 07:10 AM   #1
FrankWest
FrankWest's Avatar
Default 1933 model b pops out of 3 gear into neutral
My car still pops out of 3 gear into neutral sometimes while driving.
Any suggestions?
FrankWest is offline   Reply With Quote
Old 06-11-2020, 07:43 AM   #2
Zeke3
Zeke3's Avatar
Default Re: 1933 model b pops out of 3 gear into neitral
I am guessing the cause of the transmission popping out of third gear is due to excessive end play in the trans or the springs in the synchronizer are getting weak. I would probably remove the top cover and look for wear on the shift fork. Probably time to refresh the transmission.
Zeke3 is offline   Reply With Quote
Old 06-11-2020, 10:59 PM   #3
63tango
Default Re: 1933 model b pops out of 3 gear into neutral
I agree ^^^
63tango is offline   Reply With Quote
Old 06-12-2020, 05:34 AM   #4
Terry,OH
Terry,OH's Avatar
On the 33 trans. the center hub of the syncro has to be able to move on the main shaft about 3/16" between 2nd and 3rd. If it hangs up on the main shaft then shifts can not be complete. This could lead to your problem. Suggest you take the top of the transmission off and inspect.
Old 06-12-2020, 06:55 AM   #5
FrankWest
FrankWest's Avatar
Thanks..sounds like a great starting point. I have to find my van Pelts transmission book..
It has been a while since I looked at it. I am hoping that it is something I can replace, without removing the transmission from the car.
