Old 05-13-2020, 04:59 PM   #1
jack orchard
Default Center Exhaust Port Crack
Anybody have any advice on the repair of this crack? This is the center exhaust port of an 8ba.
Proud FNG
We fixem cars. Heap Good!
jack orchard is offline   Reply With Quote
Old 05-13-2020, 05:09 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Center Exhaust Port Crack
Would it be possible to "V" grind it, preheat and then weld with nickel rod?
19Fordy is online now   Reply With Quote
Old 05-13-2020, 05:13 PM   #3
jack orchard
A good man could. No good men around here. I don't think i could.
By the way, it is a very small leak. Takes over 2 hours to leak from 40 lbs to 5lbs.
Proud FNG
Old 05-13-2020, 05:30 PM   #4
19Fordy
19Fordy's Avatar
Jack, If you have an arc welder I bet you could do it. Get an old piece of cast iron and practice. There's also lots of videos on how to do it. It's not as difficult as it may seem.
Peen with ball peen hammer to relieve stress as it cools down.
https://www.lincolnelectric.com/en-u...t/not+provided
and
http://www.thewelderswarehouse.com/b...ing-cast-iron/
and finally
https://www.youtube.com/watch?v=0IkpAsNDbOo
Old 05-13-2020, 07:03 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
I think it was already repaired, the coloring on the gasket surface looks like there is a ground flush weld, and a crack in the shape of the marker line would usually extend through the gasket surface
Old 05-13-2020, 07:08 PM   #6
Tim Ayers
I'm hoping Ronnie Roadster chimes in. He's used sodium silicate to seal cracks in blocks.
I know it works since he's raced with some of these blocks. Just not sure if it works for exhaust port cracks.
Old 05-13-2020, 07:13 PM   #7
KiWinUS
KiWinUS's Avatar
Tim we have used sodium silicate for many years in race blocks & heads. It will destroy a radiator for long term use
Old 05-13-2020, 07:15 PM   #8
Tim Ayers
Interesting. I didn't now that. Can you get it to "cure & coat" or is it always in a gel-type state?
Hey Tony, I didn't forget about that pan. Well, I kind of did. I'll email you tomorrow.
Old 05-13-2020, 07:17 PM   #9
jack orchard
No. It is an active crack, discovered with a pressure test and soapy water.
I marked it with a Sharpie because it is very hard to see.
Proud FNG
Old 05-13-2020, 08:49 PM   #10
Ronnieroadster
Ronnieroadster's Avatar
it would be best you try the welding first and as a back up I would also use sodium silicate for added protection. However the sodium silicate is not meant to be left in the cooling system for an extended period. Its simple to use just add it to straight water. It wont work correctly if antifreeze is in the system. It sets up into a glass coating in the crack at the location of any leaks the set up temp is 140 degrees. After a while just change the water and you will be fine. Like Tim wrote above I have had excellent success using it to seal some bad cracks in my all out race blocks. Sodium silicate is the same stuff used in just about all of the head gasket/engine block crack products sold in most auto parts stores {for a lot of money}in a diluted form. You can find it on ebay where a gallon will cost less than the auto parts store small bottles and your buying it undulated so it will work much better. I forgot to add a fancy name ceramic block sealer is simply sodium silicate diluted its not full strength also in the old days it was called water glass sold in most drug stores theres lots of uses for sodium silicate.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 05-14-2020, 07:46 AM   #11
Charlie ny
Yep that's the stuff farmers called WATER GLASS way back....
Charlie ny
Old 05-14-2020, 11:30 AM   #12
bobH
Charlie ny
Yeah, and the last time I bought some, I sourced it at the local drug store.
bobH is offline   Reply With Quote
Old 05-14-2020, 12:29 PM   #13
flatheadmurre
flatheadmurre's Avatar
There´s a much easier aproach for this kind of cracks then welding.
With pressureplates installed hook it up to a vacuum pump.
Apply seal-all to the crack...shut off vacuum still applying seal-all.
Heatcure with torch.
It bonds with the rust and makes a permanent repair.
You really want belt and suspenders...add ceramic blocksealer to coolant at startup.
Old 05-14-2020, 01:29 PM   #14
19Fordy
19Fordy's Avatar
That seems like a great solution.
Old 05-14-2020, 02:58 PM   #15
40 Deluxe
Do you drill the ends of the crack when using this method?
Old 05-14-2020, 03:10 PM   #16
flatheadmurre
No drilling just adding the sealant...works real well for thoose tiny cracks you cant reach to drill and pin.
Old 05-14-2020, 03:53 PM   #17
tubman
tubman's Avatar
This stuff?
Old 05-14-2020, 03:58 PM   #18
flatheadmurre
https://goodson.com/collections/crac...polymer-sealer
Old 05-14-2020, 04:14 PM   #19
tubman
tubman's Avatar
I didn't think it could be that cheap and easy.
Old 05-14-2020, 08:59 PM   #20
Ronnieroadster
Originally Posted by flatheadmurre View Post
I tried that stuff its not worth the effort just more diluted product! The sodium silicate is a lot better and for less than halt that price for a gallon take a look.
Sodium Silicate 37.5% Type N - 1 Gallon Water Glass Auto Repair Head Gasket on Ebay for $22.99 a whole gallon
Ronnieroadster
