can anyone help me with the paint code for a '50 Ford gray dash?? Thanks!
I can't help but isn't there a little silver in it??
I'm going way back with my memory. Paul in CT |
Your best bet if available is to remove the glove box door and have it matched at an auto paint supplier.
Most old paint codes are useless now because paint formulas are vastly different. A really good body shop can create a very close match. Painting a dash usually requires removal, anyway to get an acceptable result, making testing any good spots not diminished by age or exposure possible.
I did mine with "silver argent " looks sharp it's a silver metallic
Cecil, tcp global would have the paint in the correct color
Hope this link works, your paint code might be here. Look through all of the pages that come up when you search on a ‘50 Ford.
https://www.autocolorlibrary.com/ |
I've heard both good and bad reports on some of TCP Global's paint matches. They are about the only ones that will do it without a part to compare with.
Thanks for all the advice. I did get the PPG formula from a friend in NY who had redone his dash in the past. He had obtained the formula from the late Cecil Goff, former '49-'51 advisor for the EFV8 Club, sometime in the past.
Note: the dash is out of the car and has been blasted, |
Cecil
Could you post the paint codes I am sure others, including me, would appreciate it. Seemed to me the their were different dash paint finishes for the Deluxe coupes/sedans and the Custom coupes/sedans. Convertibles were also different. Tom |
#13 |
Interior paint color also varied with the exterior color.
#14 |
I have the mix formula for Tan and Gray, both in Acrylic Lacquer. That is not what I wanted. My paint shop is looking , this week, to se if they can match a single stage to it and then I will post the results!
#15 |
Cecil
Thanks for the reply, wait to hear. Tom |
#16 |
