Old 04-18-2020, 11:32 AM   #6
xelhan
Default Re: Dana 44 2.72:1 ring & pinion
Picture of my axle housing.
This is from Wikipedia:
General specifications
Ring gear measures 8.5 in (216 mm)
Ring gear measures 8.9 in (226 mm)
OEM Inner axle shaft spline counts are 10, 19, 29, 30, 32, 33 and 35
Pinion shaft diameter: 1.375" (most Dana 44s) 1.625" (JK rear 8.9" Dana 44s)
Pinion shaft splines and spline diameter: 26/1.12" (most Dana 44s post 1970), 24/1.25" (JK), 10/1.12" (early pre-1970 Dana 44s)
Gear ratios range from 2.72:1 to 5.89:1
Carrier break: 2.72:1 – 3.73:1 and 3.92 – 5.89:1. 6.17:1 (Volvo C202)
xelhan is offline   Reply With Quote
