03-10-2020, 08:14 PM | #1 |
Auto Lamp 9000 info needed
I am rewiring my 1941 Ford Deluxe and have an Auto Lamps 9000 turn signal unit. I would like to have the schematics to it as well as any info regarding what needs to be done so it will work with my new 12 volt system (it says 6 volt only on the outside but....). I'd like the indicator lamp to also work as this unit doesn't reset after you turn. I do have some schematics but they're fuzzy. Anything anyone can do I'd appreciate.
Olefrank |
03-10-2020, 09:51 PM | #2 |
Re: Auto Lamp 9000 info needed
First google Signal Stat wiring diagram, they should be about the same re wiring. You would only need to change the indicator bulb in the unit to 12 volt, along with flasher/bulbs/fuse that matches the system.
Next, this section is for questions about the site not car related. Your best bet is to post your question on the Early V8 forms. https://www.fordbarn.com/forum/forumdisplay.php?f=4
I know the voices aren't real but damn they have some good ideas! |
03-10-2020, 10:36 PM | #3 |
Olefrank |
