Old 02-12-2020, 05:21 PM   #1
Matts30coupe
Default Babbitt Work needed in IL. Anyone!?!
Just tore down my 29 motor to find out that the mains babbit is trashed.. Was wondering what something like this cost to do? Located in Joliet IL
Matt
Matts30coupe is offline   Reply With Quote
Old 02-12-2020, 05:47 PM   #2
tinkirk
tinkirk's Avatar
Default Re: Babbitt Work needed in IL. Anyone!?!
Call Rich at Antique engine rebuilders
Skokie Illinois
Great guy
tinkirk is offline   Reply With Quote
Old 02-12-2020, 08:00 PM   #3
chrs1961815
chrs1961815's Avatar
AER does not do babbit, only inserts. Not a lot of people do it anymore.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 02-12-2020, 10:23 PM   #4
Aok
Aok's Avatar
I did have engine rebuilt by Aer 6 years ago and yes it was a insert but quality work. I sold the car 2 years ago.
Aok is offline   Reply With Quote
Old 02-12-2020, 10:33 PM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Where’s Kronke?
Old 02-12-2020, 10:38 PM   #6
Benson
Be careful who you pick to do babbitt work.
It is NOT an easy job ... experience counts
Herm Konhke does very good babbit work for 52 years
http://www.kohnkerebabbittingservice.com/our-story.html
ADDRESS
​60615 330th Ave
​Clare Iowa
​50524
Email: [email protected]
Phone #: 1-515-303-0363
Old 02-13-2020, 03:36 AM   #7
rrich1
rrich1's Avatar
Quite a few people in my model a club (central il) take theirs to Rons Machine Shop in Ohio.
rrich1 is offline   Reply With Quote
Old 02-13-2020, 08:05 AM   #8
DD931
DD931's Avatar
I strongly recommend Schwalm's Babbitted Bearings, Inc. In Strasburg, PA. 717-687-6976. They specialize in Model A engines and have years of experience. Flawless reputation. I had just had them do an engine for me.
DD931 is offline   Reply With Quote
Old 02-13-2020, 08:49 AM   #9
chrs1961815
Just my opinion: the industry is shifting away from babbit for several reasons: one, modern cars have inserts; two, inserts don't require as much special knowledge and equipment as babbit. But with that the inserts when damaged will fail right away as opposed to babbit which you might be able to limp home with. I would go with inserts, but if the rest of your babbit is OK, maybe that would be more cost effective. Though it is best to replace everything while you are in there.
Old 02-13-2020, 09:27 AM   #10
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
One or two thoughts to ponder. Properly cast bearings will typically last just as long, -if not longer than inserts will. The key here is ensuring the poured bearing material is of the proper composition and has been cast properly.
Another misconception is that once an engine has been machined for inserts, a home hobbyist can replace the insert shells should an insert bearing fail. Unfortunately that is not been the case on my experience. If the bearing is spun within the cap or block, the cap must be line-bored again. If the block is damaged, then line-boring is not an option due to timing gear lash. If the crankshaft is damaged, it is generally not as easy to exchange crankshafts due to thrust clearances.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-13-2020, 11:48 AM   #11
Seth Swoboda
Seth Swoboda's Avatar
Effingham Regrind still does Babbitt work. I have used them before and they do a great job. Located in Effingham, Illinois.
Old 02-13-2020, 12:30 PM   #12
Benson
James Rogers in N C
http://www.model-a-ford-4bangers.com/
Old 02-13-2020, 12:36 PM   #13
Jim Brierley
I recommend Schwalm's, they do great work. I also agree with Brent as to longevity.
Old 02-14-2020, 02:03 PM   #14
kbinde2
kbinde2's Avatar
I would also give a thumbs-up to Ora and the Schwalms folks. Great to work
with and I am satisfied with my rebuild. Maybe a distance to travel or ship, but worth the look or a phone call.. IMO/kb
kbinde2 is offline   Reply With Quote
Old 02-14-2020, 02:31 PM   #15
PalAl
PalAl's Avatar
A lot of Rock-Ford-A's (Rockford IL) members have used
Lashelle Engine Restoration
1802 Crossroads Lane North 2
Freeport, IL 61032
(815) 821-3546
And I believe they have been very satisfied with Jim Lashelle's babbit work.
It's nice to be within driving distance of the shop your using
Perhaps someone who has worked with Jim will jump in.
PalAl is offline   Reply With Quote
Old 02-16-2020, 09:04 PM   #16
Matts30coupe
Thanks to all that replied!! What a great community here. I will look into a couple of these and see what cam be done. Thanks again!!
Matt
