Has anyone used the improved one piece cast model B fan before. It was supposed to be fords fix to the cracking two piece ones.
Save it for judging and run an aluminum one for everyday.
Your title says steel, I thought they were aluminum? Be sure to buy a new one from a reputable supplier, some of the earlier ones had problems.
Charlie Stephens |
Aluminum ones are reproductions. The one in the photo is steel.
Have to look for seam on back side, it's not cast
Shelbycsx,
If possible how about some detailed pics of the rare fan blade? ![]() Bob-A
Model A Ford Garage comparison of A and B blades. They say the four blade eventually was the replacement for both. They didn't talk about a cast version so it must be something really odd.
http://www.fordgarage.com/pages/twobladedfans.htm |
As mentioned in post 8:
http://www.fordgarage.com/pages/twobladedfans.htm Paragraph 3 of Vince's webpage as mentioned above: 1. The Model A fan was very prone to cracking 2. was replaced with an improved construction Model B style. 3. The Model B fan was also known as the Holley design fan. Paragraph 4: Version 2. At a glance it looks like every other fan, but it is a much improved construction, and was Ford's fix to the fan cracking problem which was becoming apparent at that point in time. These improved Model B fan blades are made from a single piece steel stamping. Comment: This second version of stamped steel fan might be the one that is called "cast"? Last edited by Benson; 02-04-2020 at 02:37 PM. |
