Old 01-29-2020, 01:57 PM   #1
Shelbycsx
Default Model B one piece cast steel fan blade
Has anyone used the improved one piece cast model B fan before. It was supposed to be fords fix to the cracking two piece ones.
Shelbycsx is offline   Reply With Quote
Old 01-29-2020, 03:05 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Model B one piece cast steel fan blade
Save it for judging and run an aluminum one for everyday.
Old 01-29-2020, 03:39 PM   #3
Charlie Stephens
Your title says steel, I thought they were aluminum? Be sure to buy a new one from a reputable supplier, some of the earlier ones had problems.
Charlie Stephens
Old 01-29-2020, 03:41 PM   #4
Shelbycsx
Aluminum ones are reproductions. The one in the photo is steel.
Old 01-29-2020, 06:01 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
Have to look for seam on back side, it's not cast
Old 01-29-2020, 06:16 PM   #6
Keith True
Keith True's Avatar
Did Ford make the cast steel fan? I have one,I just thought it was something aftermarket from the 30's,40's,50's,etc.I bead blasted it and used it.It IS a cast unit,not like the late 31 single layer fan.No seam in the back.It is very thin compared to the aluminum fans,but thicker than the original 31 single layer fan.I am running it on my truck,with what I call a tubular water pump.No packing nut,fully enclosed for the whole length of it with one grease fitting in the middle.
Old 01-29-2020, 06:23 PM   #7
Bob-A
Bob-A's Avatar
Thumbs up Re: Model B one piece cast steel fan blade
Shelbycsx,
If possible how about some detailed pics of the rare fan blade?
Bob-A
Bob-A is offline   Reply With Quote
Old 01-29-2020, 07:26 PM   #8
Sunnybrook Farm
Sunnybrook Farm's Avatar
Model A Ford Garage comparison of A and B blades. They say the four blade eventually was the replacement for both. They didn't talk about a cast version so it must be something really odd.
http://www.fordgarage.com/pages/twobladedfans.htm
Sunnybrook Farm is offline   Reply With Quote
Old 01-31-2020, 02:37 PM   #9
Benson
As mentioned in post 8:
Paragraph 3 of Vince's webpage as mentioned above:
1. The Model A fan was very prone to cracking
2. was replaced with an improved construction Model B style.
3. The Model B fan was also known as the Holley design fan.
Paragraph 4:
Version 2. At a glance it looks like every other fan, but it is a much improved construction, and was Ford's fix to the fan cracking problem which was becoming apparent at that point in time. These improved Model B fan blades are made from a single piece steel stamping.
Comment: This second version of stamped steel fan might be the one that is called "cast"?
