Old 01-29-2020, 12:00 PM   #1
Mulletwagon
Mulletwagon's Avatar
Default Cold Weather Shifting
After a spell of wind chill in the 50s down here, I noticed no amount of double clutching or rpm modulation would prevent gears grinding until the trans warmed up. Is this typical for running As up north during serious cold ? If so, what is a good shifting technique until the trans limbers up and shifting returns to normal ?
Mulletwagon is offline   Reply With Quote
Old 01-29-2020, 12:06 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Cold Weather Shifting
What are you running in the tranny for lube??
Paul in CT
Old 01-29-2020, 12:08 PM   #3
Tacoma Bob
Tacoma Bob's Avatar
Had this happen a couple of times up here in Tacoma. I found just letting the car warm up before heading out works. Like 20 minutes or so.
Tacoma Bob is offline   Reply With Quote
Old 01-29-2020, 12:17 PM   #4
Mulletwagon
Paul in CT
Fresh 600W. Just put in a new clutch disc.
Old 01-29-2020, 01:00 PM   #5
Jacksonlll
Jacksonlll's Avatar
The lube is stiff and will stop the spinning gears quickly, so shift quicker and at lower speeds.
Old 01-29-2020, 01:41 PM   #6
ryanheacox
ryanheacox's Avatar
Shift quick, don't double clutch the upshifts until the oil warms up. Thats the way I did it when it was 10 outside and I only let the engine warm up for a few minutes.
Edit: Jack beat me to it
Old 01-29-2020, 05:47 PM   #7
Big hammer
Drive in low gear at a slower than normal speed, the colder it is the long time is need to get the 600w oil to flow. When I was driving my A daily and the temperature was 0* I could not put the shifter in to gear because the oil was so stiff. I learned to put the shifter in to the gear I was going to leave in or it would take two hands to move the gear shift.
get a bigger hammer tap done
Old 01-29-2020, 05:57 PM   #8
Kurt in NJ
Kurt in NJ's Avatar
Below freezing it takes some effort to move the shifter, steady pressure instead of forcing, then I go a block or two in first, after that I drive normally---(shell Omaha 680 gear oil)--- in the owners instruction book there are suggestions of thinning the oil with kerosene for cold operations--- I don't, have found the short time in first loosening it up enough---
Old 01-29-2020, 11:48 PM   #9
warrene
Who would use TAR in their transmission, that's what that junk is. try to drain it out, put in 80-90 same as a modern car or truck, that's what belongs in the thing, same thing in the rear end, 600 doesn't even have EP in it, you want to wreck your gears ... leave it in.
warrene in Minnesota where it can be 30 below shifting.
warrene is offline   Reply With Quote
Old 01-30-2020, 08:04 AM   #10
rocket1
Oh no not another discussion on proper lube!!!
rocket1 is offline   Reply With Quote
Old 01-30-2020, 08:17 PM   #11
Mulletwagon
Tried the single clutch quick shift and it worked great. Ryan You Da Man !!
Old 01-31-2020, 01:37 AM   #12
Bill G
Bill G's Avatar
Up here in Washington State, it gets cold but admittedly not as cold as the midwest! I noticed right off in the winter that it takes a mile or two for the transmission to warm up. Yes, when cold definitely faster shifts at lower rpm, otherwise a need for double clutching or grinding.
Old 01-31-2020, 06:37 AM   #13
ryanheacox
ryanheacox's Avatar
Glad I could help!
Old 01-31-2020, 01:05 PM   #14
Big hammer
And how cold was it in the Midwest, it was so cold we didn't exhale on the windshield or frost would form on it ! We would exhale on the side windows.
Old 01-31-2020, 01:08 PM   #15
DD931
DD931's Avatar
A friend recommended putting about 50% STP with 80/90 regular gear oil in the tranny to aid in shifting. Comments?
DD931 is offline   Reply With Quote
Old 01-31-2020, 03:22 PM   #16
The Master Cylinder
The Master Cylinder's Avatar
I agree. Even in SoCal on a cold morning I have to shift early to get in second and third. Downshift? Forget it when it is cold.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 01-31-2020, 10:43 PM   #17
Forddan
You can take a look to my first posting of this thread..... and if you have time you can read the rest.
https://www.fordbarn.com/forum/showthread.php?t=272671
Forddan is offline   Reply With Quote
