#41 | |
#42 | |
#43 |
One other thing to consider if you have run it with old fuel it can coat the plugs even with fresh fuel in it ,we had a 29 Dodge in the shop it was missing we did everything ,it sounded like a carb issue bolted the carb up to a 26 Chev it ran fine so that eliminated that , put new plugs in it and Bingo !
#44 |
When I swapped the engine into my F1, I ended up with a coil/external resistor miss-match that wouldn't allow it to pull hard or rev above approx 2500 rpm. Acted just like a fuel starvation issue. I by-passed the resistor and all was good. I now use the blue Bosch that Bubba recommends.
"whatever works!" |
#45 |
ill be checking back in when weather gets better to do more work. I did pm CharlieNY to see about a carb rebuild.
I have (4) 94 carbs but only one is rebuilt. All have the same base with AA-1 on it. and dont see any valve or other component on them. Ill pull the cover and head and make sure the timing is correct. Im an punctilious re-builder and if I got this off, its major confession time. |
#46 |
#47 |
Believe the Flamethrower coils come in both 1.5 & 3.0 ohms, so you would want to check and see what it is.
#48 |
Just check that you don't have the early inlet manifold were the heat riser hole lines up with the 94 ,
#49 |
Yeah the flame thrower is not going to help you on a standard dizzy. Backup and fix one thing right at a time. Not a big deal till you start driving it a while.
If you want the vac advance, look at charlie to do your carb and dizzy. If you want mechanical advance, charlie or bubba can do that. Skip on coil. including cans. Surrender and let them set it up. It's a good starting point, till you find someone local or even then. Sometimes it takes time. I'm a fan of starting and running stock first, then mod. . Last edited by Tinker; 01-29-2020 at 11:07 PM. |
#50 |
Flathead Ted, what does "check that you don't have the early inlet manifold were the heat riser hole lines up with the 94" mean.
I did swap intake manifolds with this rebuild but still have the old one. what do I look for? I don't know what the heat riser hole will look like. Thanks for the help, God Bless. |
#51 |
See that hole half way between the two front carb studs? You don't want an intake with that hole if you are running a 94.
Mart. |
#52 |
Mart, thanks! ill check it out.
#53 |
can someone help me post photos? thanks.
#54 |
#55 |
testing
#56 |
Hey it worked. nothing to see here just testing. Thanks Tinker!
#57 |
mart, flatheadted, no heat riser hole. stock manifold doesnt have one. something stupid is going on. ill keep tinkering.....
BTW, I dug up the old 94 that I had on it as a teenager and drove this truck all the time. it has a hole drilled in the carb above the accel pump plunger. not sure who did this, wasnt me but it ran like a champ. is there a reason to do this. Here is a photo. |
#58 |
I have a goodguys event comeing up in March. I have to drive this to the event regardless. ill push it if I have too. God Bless. thanks for your help.
I have not heard from CharlieNY or Bubba. I hope they are doing fine. I want to visit these guys fairly soon and see what they do. I can spend some time with them and want to carry on their knowledge. let me know if you hear from them. |
#59 |
I pulled all the plugs and all a re black so i am running rich, some were black-wet. I have black residue below the exhaust pipes on my drive. I have the 94 adjusters out only 1 turn and still seems rich.
I think I have a vacuum leak somewhere which will account for the low vacuum pressure of 15 psi. Ill double check the intake and fuel pump block-off when the weather gets better. Man, I need a heated shop! God Bless you all.... |
#60 |
That hole in the carb is correct. Not all have it though. It's a vent. Some have the vent but routed internally.
