Old 01-10-2020, 05:13 PM   #1
37fatfender
Default Two Piece Oil Pans? When were they made?
I have searched but cannot find any reference to the 2 piece oil pan. I am looking for a 2 piece oil pan, one that will let me remove the flywheel without dropping the oil pan. What year car or truck were these installed new?
37fatfender is offline   Reply With Quote
Old 01-10-2020, 05:36 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Two Piece Oil Pans? When were they made?
Don't ever remember seeing one but it wouldn't take much to strategically cut the bell housing portion off and create a bolt together joint to allow it to be removed.
Old 01-10-2020, 05:46 PM   #3
Stenny
I have no date when these were released but I believe it was for the 59 AB trucks with the larger clutch. I have a few on the shelf and can snap some photos if you want to see what they look like.
Stenny is offline   Reply With Quote
Old 01-10-2020, 06:31 PM   #4
Brian
Brian's Avatar
I agree with Stenny; jailbar trucks had them
Old 01-10-2020, 06:42 PM   #5
19Fordy
19Fordy's Avatar
Here's one 2 piece.
https://picclick.com/1946-1948-Ford-...718261268.html
19Fordy is online now   Reply With Quote
Old 01-10-2020, 06:51 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Here ya go! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-10-2020, 07:08 PM   #7
Brian
Brian's Avatar
And there is two versions ; one has the regular big drain plug, the other has the big clean out removeable plate.
Old 01-10-2020, 07:26 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
Brian....Actually, there are at least three types. This one is supposedly Canadian heavy duty truck application. DD
T5 W/TORQUE TUBE
Old 01-10-2020, 08:52 PM   #9
Jay in Mass
I have known about them and using them for years. They certainly do make life a lot easier when doing a clutch and flywheel job.
Jay in Mass is offline   Reply With Quote
Old 01-10-2020, 10:05 PM   #10
Brian
Brian's Avatar
Coop, Thanks for the photos, that yellow one shows the big clean out removable plate I mentioned, what is the third type?
Old 01-10-2020, 10:44 PM   #11
37fatfender
What years were they made? Thanks everyone for the pictures and info.
Old 01-10-2020, 10:54 PM   #12
G32
Ford-ers;
Note the difference in the road draft arrangement -- a bolt on draft tube
extending aside to rear of the engine rather than the slotted tri shape
can --more Canadian &/or Export than USA -just My opinion
More neat Ford stuff & practical! Love it
Gene Tulsa
Re picture in post # 8
G32 is offline   Reply With Quote
Old 01-10-2020, 11:25 PM   #13
26 lakes
The yellow pan is Canadian military. 1942-48 Part#6675. I have one of the military two piece pans and a regular two piece pan. Both oil bosses on them do not have a place for a oil return line. They do have one in the side of the pan. I believe that would make them 1942 and earlier.
26 lakes is offline   Reply With Quote
Old 01-11-2020, 02:06 AM   #14
Newc
Newc's Avatar
Hi all; I restored a low miles '48 Canadian M-37 1/2 ton pickup and it came with a 2 piece pan. All the rest I have seen were on big trucks/COE's too. Newc
Old 01-11-2020, 06:13 AM   #15
Tim Ayers
If anyone has just the pan for sale, I’d be interested. I have the back piece.
Old 01-11-2020, 07:33 AM   #16
Ziggster
Lol. The yellow one is mine. It came off a C59A (or C69/AT according to rebuild tag). Mine was used as an industrial engine out in western Canada. It was disaassembled when I purchased it, and the seller provided me with two remote oil filters. There is no oil return line in the pan that I can recall.
Ziggster is offline   Reply With Quote
Old 01-11-2020, 10:20 AM   #17
V8COOPMAN
V8COOPMAN's Avatar
Brian.... 1st with a normal, small drain plug. 2nd with large, steel ROUND clean-out hole. 3rd with this OBLONG style, steel clean-out-shaped plate cover like YELLOW above. DD
T5 W/TORQUE TUBE
Old 01-11-2020, 04:45 PM   #18
coolcoupe
coolcoupe's Avatar
Does this mean a person doesn't have to remove engine to replace clutch plate ?
coolcoupe is offline   Reply With Quote
Old 01-11-2020, 04:54 PM   #19
34PKUP
34PKUP's Avatar
Still have to remove the engine or the transmission but don't have to remove the oil pan.
34PKUP is offline   Reply With Quote
Old 01-11-2020, 11:49 PM   #20
qmdv
qmdv's Avatar
And that is kind of nice especially if you have no leaks in the pan or seals
qmdv is offline   Reply With Quote
