Old 01-08-2020, 07:44 PM   #11
James Y
Default Re: FINALLY…T5 WITH Torque Tube in a ‘35-’40 Ford...The WHOLE STORY!
Just wanted to shout out a thank you to V8 Coopman and everyone else for figuring this out. I followed the directions and with minimum fab skills managed to put it togeather. I used the factory plate on the bottom of the crossmember box as reference. And had various thickness of plates made up to support the trans and position the wishbone as close to the factory position as possible.
Also the adapter from Kato kings is top notch, beautiful work.
First time I have ever did this type of project, but followed it thru and turned out great, can’t wait to drive it one day.
James Y is offline   Reply With Quote
