Old 03-28-2011, 12:00 PM   #41
Budds Auto
Default Re: Fleathead Engine Stands
Nice stuff there fellas, just added one of these stands to my own wish list!
Budds Auto is offline   Reply With Quote
Old 03-28-2011, 03:23 PM   #42
southfork
southfork's Avatar
So what is the angle on these adapters? If you build one, either by cutting the tube at an angle, or by using angle iron, you want the engine to mount up flat when you look across the top or the bottom of it. It it a 45 degree angle from vertical on the adapter face, or some other angle???
southfork is offline   Reply With Quote
Old 03-28-2011, 06:59 PM   #43
okiedokie
okiedokie's Avatar
PM coming your way Tman.
okiedokie is offline   Reply With Quote
Old 03-28-2011, 08:54 PM   #44
Ralph Moore
Ralph Moore's Avatar
It's hard to believe that only using four exhaust bolt holes is stronger than six bell housing bolts???
I just made an adapter for an extra stand I had that will bolt to the bell housing mount holes on a 49-53 motor.
Is this going to have a chance of breaking the block?
Ralph Moore is offline   Reply With Quote
Old 03-30-2011, 11:56 AM   #45
daveg2
Here's a picture of my AMMCO stand. I've had it for about 40 years. I've built some nice flatheads on it. I plan to paint it and then get a flathead to mount on it. Will repost pictures once I get the stand painted. Does anyone know for sure what color it was originally? By the looks of it I think it was blue, but can't be sure.
daveg2 is offline   Reply With Quote
Old 03-30-2011, 12:12 PM   #46
Henry/Kokomo
Henry/Kokomo's Avatar
The late blocks - the ones without the cast on bell housing - will be fine. It's not the strength of the bolts that matters, it's the strength of the casting. The bell housing part of the early style block castings is somewhat thin compared to the weight being supported and the length of the effective lever arm.
Henry/Kokomo is offline   Reply With Quote
Old 03-30-2011, 01:03 PM   #47
Tim Ayers
Dang, that's really cool. Should put an electric motor on it so a flathead would spin around it stand's uprights.
Old 08-26-2011, 11:18 AM   #48
Richard
Richard's Avatar
I am looking for a complete v8 KR wilson stand.
I am a believer
Richard is offline   Reply With Quote
Old 08-26-2011, 12:36 PM   #49
37ford4dr
37ford4dr's Avatar
i drilled mine and mounted it to the engine and then welded it to the mounting plate.
37ford4dr is offline   Reply With Quote
Old 08-26-2011, 04:13 PM   #50
Dave27
Originally Posted by lowride View Post
Here are two KR Wilsons, One with and one without a base. Then there's another that we made.
I like the one you made i need one like that for my spare motor.
Dave27 is offline   Reply With Quote
Old 08-27-2011, 11:25 AM   #51
Kurt in NJ
Kurt in NJ's Avatar
I modified the base of an engine stand I found in the trash for my KRW stand, the wide stance makes it very stable.
Old 09-17-2011, 11:37 PM   #52
ivertek
Thumbs down Re: Fleathead Engine Stands
Hi All.. I am new to the forum, but thought some of you may be interested in this.
I am cleaning out my barn, and it is time to sell my K R Wilson engine stand. It is missing the tool tray, but does have the rolling base, and an extra long u-channel for even more stability. Has a home-made mounting plate for muscle car work.
It's been a good friend to me, so I'd like it to go to a good home. I'll post more detail in the SwapMeet section.
Gary
ivertek is offline   Reply With Quote
Old 10-07-2012, 12:27 PM   #53
Chris Haynes
Chris Haynes's Avatar
http://www.fordbarn.com/2012/09/06/f...-engine-stand/
1921 Runabout
1930 Tudor
Early 1930 AA
Old 10-07-2012, 12:33 PM   #54
Tim Ayers
It's not so much that four exhaust bolts are stronger, it's that when a flathead is "hung" by the bell, that is a lot of weight trying to pull it downward and thus putting a lot of torque on the bell housing.
I've heard and seen a more than few flathead with broken bells because they were hung this way. Of course, others have hung a flathead this way for years without issue.
Old 10-07-2012, 05:18 PM   #55
V848 Ford
The pictures of the flat head mounts are neat does any body have any of the T and A mounts so I can fab some?
V848 Ford is offline   Reply With Quote
Old 10-07-2012, 07:32 PM   #56
1937pickup
this has been a great post-loved the link to KR Wilson and reading about him and the business. I think his tools were so good because he understood the problems that needed to be solved.
1937pickup is offline   Reply With Quote
Old 10-10-2012, 01:47 PM   #57
thirt4
thirt4's Avatar
These are pictures of my test stand. I have the KRW stand complete also but that is for hanging and working on the engines. My KRW has heavy square "U" channels screwed to the base of the KRW and is wheeled. The screws / bolts are the Allen head, countersunk type. My third is a short wheeled stand for moving the engines around the shop with.
thirt4 is offline   Reply With Quote
Old 10-10-2012, 08:29 PM   #58
Pete Fl/Wi
Pete Fl/Wi's Avatar
I use this for building top end and short test for leaks, carb setup and timing.
Pete Fl/Wi is offline   Reply With Quote
Old 10-16-2012, 08:37 AM   #59
DetroitMotion
So again, the late style (non-integrated bell housing) engines will be fine when mounted in a traditional position? You have me worried as I put mine on a stand yesterday..
DetroitMotion is offline   Reply With Quote
Old 10-16-2012, 09:46 AM   #60
Bruce Lancaster
I've seen pictures of Bishop's amazing stand...it was designed specifically with his porting interests in mind, and essentially allows all cuts to be made in about the same position and direction...no weird anles to be ground while bent over and peering upward! It somehow reminds me of a WWII ball turret mount.
I like the Clayborn for compactness and excellent access to everything; its only weakness is that it has a narrow stance and so might be troublesome when using a KD valve bar on a totally stuck guide. Not a problem if you have more than brute force tools and skills for the guides...
