Old 12-03-2019, 05:09 PM   #7
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Erratic Water Temps in '56 Y block
Originally Posted by JimNNN View Post
Have you ever thought about a decent quality mechanical gauge? Originality is nice, but if the engine is original, it would be nice to know precisely what the water temperature is so that the original engine doesn't get damaged. I kept the substandard factory electrical gauge for far too long.
Before installing, you can put the sensor of a mechanical gauge in a pot of water that's just coming to a boil to find out exactly how accurate it is. You can also find out how exactly how much the engine is heating up on summer days after you shut the engine off.
Good idea here. Heat soak amount.
The FYB had the coolant temp sensor located in the wrong spot as it sees only coolant temp coming out of only one bank of cylinder barrels. It does not see the temp gained while crossing the adjoining exhaust valves on cyl(s) #6/7 left bank and #2/3 on the right bank which are hot because of another design flaw.
A mechanical gauge will be much more accurate. The sensor should be located in the front coolant cross-over at the front of the intake manifold.
If you have a BIRD, you need to be aware of other cooling system design flaw(s).
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
