Old 11-01-2019, 01:54 PM   #1
Gary Karr
Gary Karr's Avatar
Default Original coils. Can they be rebuilt?
Can original Model A coils be rebuilt? I have a couple of early '28 script slant poles that do not work. I though I remember hearing that a new coil could be put inside the casing or another working original coil could be put inside the casing. Thoughts?
Gary Karr is offline   Reply With Quote
Old 11-01-2019, 04:12 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Original coils. Can they be rebuilt?
Gary, John Holland was the guru on rebuilding these but as I understand it, he no longer has cores. I have wondered about having a new spool wound and then pot it in epoxy. I would start by calling John and see what he says.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-01-2019, 09:51 PM   #3
Ray in La Mesa
Some years ago Jack Simmons in our San Diego club switched out the innards of a slant coil with a new coil, messy but it worked & you couldn't"t tellfrm the outside.
Ray in La Mesa is offline   Reply With Quote
Old 11-02-2019, 09:17 AM   #4
Kurt in NJ
Kurt in NJ's Avatar
I bought a new epoxy coil some years ago to put inside original can, the outside diameter is a little large, got the coil Xrayed , saw that there was enough thickness to cut it down to fit ----I have not worked on that project, have a "Ricks show quality script coil", a japan oil filled coil with a tin cover slipped over it, easy to see it's not correct, but it has the hottest spark of any coil I have used so it hasn't been a priority ---don't know if you can still buy the usa epoxy 6V coil though
If Skip who does V8 coils can do the 32 tall coil he has innards that should fit the A can
Old 11-03-2019, 10:59 AM   #5
DD931
DD931's Avatar
Skip Haney in Florida does V-8 coils. Ask him if he does Model A's!!
DD931 is offline   Reply With Quote
Old 11-03-2019, 01:39 PM   #6
cjkohnast
I have a new 6 volt coil for sale $10 I can measure it up if some wants to try inserting in an old caseing John
cjkohnast is offline   Reply With Quote
Old 11-03-2019, 07:31 PM   #7
jb-ob
Please understand I'm a paint guy......if Ford changed the coil's polarity after November 1929, wouldn't the 'new' guts for an early pre-reversal coil need to be the same ??
jb-ob is online now   Reply With Quote
