10-26-2019, 06:49 AM | #1 |
Gearbox Question 1939 / 1940
Hi Guys , my question is will the internals of a 1940 ford 3 sp gearbox (side shift) fit into a 1939 ford toploader gearbox , i have a good 40 model box and am trying to find out if i can fit the internals into a 39 box with top shift , i have a 39 box with no internals
thanks in advance Phil Perth Australia |
10-26-2019, 06:51 AM | #2 |
Re: Gearbox Question 1939 / 1940
Yes
10-26-2019, 07:07 AM | #3 |
But for your "39" shift top to work it should have the big fork with the 81A- part number embossed on it. Early 39s used the older fork.
10-26-2019, 08:53 AM | #4 |
The later gear sets from a side shift trans will definitely go into a '39 top load case, as well as the earlier top load cases. I just put the later 29 tooth cluster/15 tooth input gears into a 35 top load case, (along with having 3.54 ring & pinion in rear) and the quality of shifting is so much better than it was with the original 35 gears, like night vs. day, and this also seems to have eliminated the jumping out of 2nd gear. However, this could be mostly due to making sure all gears, spacers, etc., had nominal to minimum clearances.
I should also note that I did not use a 39 style shift tower, with the standard/original wide fork. A friend made a presission set of special forks, where all pieces required were tig welded together, that assembled directly into the stock 35 shift tower that slants back towards the rear of the car.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 10-28-2019 at 08:25 AM. |
10-27-2019, 08:31 PM | #5 |
Sent you a PM Phil
"Came too close to dying to stop living now!" |
10-27-2019, 11:55 PM | #6 |
Alan |
10-28-2019, 11:01 AM | #7 |
I have a question.
The early fork is 2.81 wide and the 91A is 2.98 wide, both by Ford specs. Can the early fork be machined to the late width?
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
10-28-2019, 01:36 PM | #8 |
The difference in the forks is not only the width of the opening but also the offset. The early fork will not function properly, even if it is opened up to fit over the synchro.
