If it still turns squirt some oll in plug holes and let it soak in while you change the oil. Turn it over by hand a few times and then with plugs out hook a 12 volt battery and crank it for 10-20 seconds.I install a mechanical oil pressure gauge where the oil sender is to verify pressure. Repeat a few times every year.
