#21 | |
Give me some figures. How many miles have you done on a rebuilt engine you have installed? Did any of the rebuild engines you fitted to your cars fail? If so, what happened?
#22 | |
On some of our long outback trips, one of the guys who uses babbit takes along a rebabbited con rod and middle main bearing cap amongst his spares. I've seen him have to use them.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
#23 | |
Okay, I of course believe you but as with almost all these types of comparisons on this forum what are we actually comparing? Are we comparing your quality insert conversion with a quality babbitt job; or rather, your quality insert conversion with a second or third rate babbitt job?
#24 |
congratulations on a job well done.
There is a book that list all the unapproved ford model A accessories that were issued in 1930's. There are several replacement carburetors listed, including a dual carburetor intake for the zenith carbs. Not sure how effective they will be because of gravity feed fuel system? But the book is a lot of fun with copes of original ad's for Model A accessories. Here is the book Lots of pictures and drawings, fun book for a Ford Model A owner https://www.abebooks.com/servlet/Boo...-srp1-_-title3 Last edited by FrankWest; 09-28-2019 at 11:37 AM. |
#25 | |
First I fitted new gaskets...leaks. By "leaks" I mean it does not seal tightly enough for 50+mph speeds; and I'm NOT talking steam, my car runs cool, I mean water being pumped by the water pump at high rpm. Then I purchased the special O-ring...leaks. An O-ring together with a gasket is too thick; quail will not close. While week after week pass ordering parts and waiting then ordering again I'm running the car on water rather than on anti-freeze. I could have tried putting Right Stuff then the O-ring but I do not want to live in fear of that patch job repair failing and anti-freeze destroying a nice paint job. My reproduction quail is poor quality...that's the problem. Add to all this if someone tries to steal the quail they will probably end up destroying the radiator neck. What the A hobby needs is non-locking caps fitted with moto-meters like Model Ts have. Game over; time to move on. I've fitted a standard cap, no leak at 55+mph.
#26 |
#27 | |
If you see such a cap for a 31 let me know!
#28 | |
Cool book but not for me. I spend enough time thinking about Model As and Ts...such a book would have me constantly dreaming and day dreaming about 4x4 conversion kits and the like!
#29 |
Do away with the Quail. Get a new cap from the vendors. Drill a hole in it to mount the motometer. A plain cap should not leak. If it does something is wrong with your radiator neck or the tabs on the cap.
#30 |
It is actually a good idea not anything to your original car but try to make it as original as possible. The only good thing I found doe me in that book was a gold tone rear view mirror clock. Not approved Ford but looks great and is from the same time frame.
#31 |
I have similar issues with the quail and motometer radiator caps leaiing. Will likely go back to the standard cap.
#32 | |
A gold tone rear view mirror clock? MARC judges would put your car in the hot-rod category
#33 | |
The way they are made I don't think you can just drill a hole in the middle for a moto-meter.
#34 |
Grind that rivet head off and drill the hole in the separate pieces, shouldn't be much of a problem. There will already be a hole though probably too small in the inner piece with the tabs.
#35 | |
Okay; but there is is a second issue. Top of the cap is domed while the moto-meters have a flat bottom stand.
#36 |
I'm guessing after you grind the rivet head off you can make it fit by working with just the cap, a hammer and something placed underneath to flatten it out or shape it as you desire. Unless there is something under the tabs that would prevent this and depending on the price of the cap you are to modify, I'd go for it. You could also use a rubber washer between the top of the cap and the motometer.
