#15 |
Here is the easiest way to prime the oil galleys and pump on an 8ba. With the filter out and the cover off put a hose over the center tube and fill the can. The oil will drip back through the pump and galleys. It will take a bit because of the small orfice in the inlet but it will drain down. I never examined anything after to prove this out but figure it must work because the oil went somewhere.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
