#18 |
I can't think of a single advantage for running any vehicle on six volts. Six volt systems run higher amps . Higher amps cause heat and shorter component life. Six volt systems have less cranking power , dimmer lights plus six volt parts and components are getting harder to find . Most cars have used twelve volts systems for over sixty years . There were several good reasons .
