Old 09-05-2019, 02:32 PM   #1
arnhemmer
Default Oil filter
What is the consensus out there regarding running a fully inserted engine with or without a full flow oil filter? One of our club members spun an inserted rear main bearing and it ceased up the motor. It is a recent rebuilt but he is running it without a full flow oil filter. Personally I thing that since inserts are harder then Babbitt a full flow oil filter should be installed.
arnhemmer is offline   Reply With Quote
Old 09-05-2019, 05:39 PM   #2
30 Closed Cab PU
Default Re: Oil filter
If rebuilt by a motor rebuilder, talk to them before attempting anything. I would think that a rebuilder at the very least would be a great source for answering your questions.
Old 09-05-2019, 05:45 PM   #3
Synchro909
Synchro909's Avatar
I run an oil filter (prefer full flow) on every Model A I have owned whether babbit or inserts. IMO, they are one of the biggest steps forward in engine design to prolong engine life. Air filter is another. Can you imagine the response you would get if you tried making a warranty claim on a failed engine in a modern car if it came out that you had removed the air and oil filters???
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 09-05-2019, 05:51 PM   #4
arnhemmer
Synchro909 I'm with you on that one. By the way ,love your Avatar. What's it like hopping around on one leg LOL.
Old 09-05-2019, 06:08 PM   #5
Railcarmover
So was the seized engine with the spun rear main caused by lack of filtration?
Railcarmover is offline   Reply With Quote
Old 09-05-2019, 08:01 PM   #6
Synchro909
Synchro909's Avatar
I have that picture laminated and I leave it in the window of my car when at shows etc. EVERYONE knows what it means without me saying a word!
BTW, That's not my leg. Someone fiddled with my car but only once.
BTW again, That is a picture of my dog, Synchro. We lost him 12 years ago now.
Old 09-05-2019, 09:15 PM   #7
arnhemmer
@railcarmover: We don't know yet, I just want to know if that could be a possibility since I have heard several recommendation to filter an inserted engine. This happened in the state of Washington after a long trip from San Jose California. He trailer ed it home and dropped the pan and found the spun bearing.
Old 09-05-2019, 09:46 PM   #8
George Miller
George Miller's Avatar
That is a common problem with the rear main with inserts. You need a oil path in the upper shell to get oil to the back of the 3 inch long bearing. If you do not do it your chances of spinning a bearing is great.
George Miller is offline   Reply With Quote
Old 09-05-2019, 09:48 PM   #9
Synchro909
Synchro909's Avatar
At what speed did he travel? These cars don't like anything over 45 at the most for sustained periods. I know, I know, there are plenty of you who say they cruise at 50 or 55 mph but I would never do that in a Model A without an overdrive.
Old 09-05-2019, 11:40 PM   #10
KenCoupe
KenCoupe's Avatar
The late Jay Steel of Taylor Engines strongly recommended full flow oil with insert bearings when he rebuilt my engine.
KenCoupe is offline   Reply With Quote
Old 09-06-2019, 12:06 AM   #11
bdtutton
I just added a full flow oil filter to my Model A because I know how much longer lawn mower engines run that have oil filters....car engines can't be any different. I had a burnt valve so I had the head off to replace and lap the valves so I decided it was a good time to replace the side cover with one that had a full flow filter. The installation was not hard.
So far the engine sounds happy, the oil pressure is a little higher because the oil has to be pushed through the filter and the oil is still so clean that I can barely see it on the dip stick.
bdtutton is offline   Reply With Quote
Old 09-06-2019, 09:04 AM   #12
arnhemmer
It will be interesting to see how his is set up and what happened to the bearing.
Old 09-06-2019, 12:43 PM   #13
Jim Brierley
I always run full-flow filters on my engines, some have been inserted, some babbit. Having said this, I worked at LAX for almost 10 years, during the time the EPA was clamping down on a lot of things, including waste oil filters. We switched-out the filters on our police fleet from OEM to a cleanable filter, sorry can't recall the brand. They had an extremely fine screen in them. They worked well, so I bought one for my 6.2 liter GMC diesel. I cleaned it religiously a few times, but never found any crud in it, so started cleaning it at every 2nd oil change. When I sold it 262,000 miles later, it still had no engine problems. So IMO, a full-flow filter is still highly recommended but I think not critical, if using modern oils. 2 diesel trucks later, I have stock filters but change them every-other change. The color of the oil doesn't tell you a lot.
Old 09-06-2019, 01:23 PM   #14
arnhemmer
He was traveling at about 55 mph in overdrive.
Old 09-06-2019, 05:38 PM   #15
Synchro909
Synchro909's Avatar
I don't think that is an excessive speed in O/D and I stuggle to see how an oil filter would have changed things for him. I wonder whether the bearing was set up with not enough clearance. I am assuming everything was OK with the return tube etc.
I have heard it said that there are plenty of engines running around out there with bearings that are too loose. There are NO engines running around with bearings that are too tight.
Old 09-06-2019, 08:17 PM   #16
updraught
updraught's Avatar
"I have heard it said that there are plenty of engines running around out there with bearings that are too loose. There are NO engines running around with bearings that are too tight."
That's very filo-sofical ...
Some info. Don't know if it is good or bad. Just sayin.
http://www.fordgarage.com/pages/AERbearinginserts.htm
Rich from AFR doesn't use a filter, according to a video he made.
However, he thinks it is a good idea.
But doesn't recommend a metal timing gear, for reasons unknown.
updraught is offline   Reply With Quote
Old 09-06-2019, 08:58 PM   #17
Aok
Aok's Avatar
I had a full flow on my 3 2 coupe with inset bearings nd it worked well but ran it for about 800 miles w/o a filter no problem. Sold car last year so can't say anymore.
Aok is offline   Reply With Quote
Old 09-06-2019, 09:40 PM   #18
Railcarmover
The most likely reason AER designed their own insert bearings is to use them in gravity fed and low pressure applications.Beware the engine builder who uses off the shelf insert bearings, the majority of them are designed for pressurized systems to keep them clean,cool and lubricated. Unfortunately when an insert bearing fails it wipes out what it bears,odds are the rear main journal took a beating in this failure as well.
Two benefits of poured babbit bearings is its ability to withstand gravity fed systems and conduct heat.When it fails it generally continues to protect what it bears by its sheer mass.unlike the thin babbit coating of the insert,the poured babbits thickness saves the rotating group from destruction for the most part.
Filters and oil are cheap..change them more often than less..
Old 09-06-2019, 11:42 PM   #19
30 Closed Cab PU
x2
I am a believer in poured Babbitt, if done correctly by a skilled mechanic. Inserts are OK, but my belief is inserts do not require as much skill to do.
Thanks rail car for the additional info. on types of inserts.
Am open to being corrected if this is incorrect.
Old 09-07-2019, 12:07 AM   #20
Railcarmover
Originally Posted by 30 Closed Cab PU View Post
x2
One of the reasons insert bearings are popular is they are no risk to the engine builder/machinist. Line bore it and snap them in,good to go. A babbit pourer has to be on his game every time for consistent quality results.From a business perspective its a wise move,minimizing warranty claims maximizes profit,it also allows for lower functioning help..
