Originally Posted by Tom Endy
I was not able to use my Model A pinion puller because of the large diameter drive shaft. I had to improvise. I used a large bearing puller and a couple of bolts. I was able to get the puller up against where the tube is welded on. By tightening the two bolts against the back plate of my Model A puller, the whole pinion assembly came right out.
Tom Endy
Tom,
I just did one and am in the process of wrapping it up.
I concur witj the guys on the driveshaft. There were different varieties up to 36 with the 37 using the intermediate bearing.
If you can get a Krw Aata puller you will find it useful.
Larry shepard
