Old 05-13-2019, 02:45 PM   #1
deuce295
deuce295's Avatar
Default Oval speedometer binds in reverse
My oval speedometer will sometimes bind up when going in reverse. Snapped my drive cable. It seems to work just fine going forward and seems to indicate speed good but when I go in reverse it will lockup sometimes. Curious if anyone who has been inside one of these would have any input. Wondering if there is an area where there could be a broken tooth on a gear perhaps. Just curious if anyone has any thoughts. Will be pulling it out as soon as i get a little time . Thanks.
deuce295 is offline   Reply With Quote
Old 05-13-2019, 08:21 PM   #2
burner31
burner31's Avatar
Default Re: Oval speedometer binds in reverse
You have two gears in there that work the speedometer, the drive gear, the big one, and the driven gear, the small one. You may have a chipped or broken tooth on one ir both. You can pull the small one and check it, the big one can be check thru the hole, jack the rear and rotate tires to see all the gears on the big one.
Keith
Shawnee OK
'31 SW 160-B
Old 05-14-2019, 06:06 AM   #3
Jacksonlll
Jacksonlll's Avatar
It's probably your main shaft in the speedo. They bind up over the years and it is very hard to free them up. Try to turn your speedo drive with your fingers. Bet you can't. It is a big deal to get that shaft out without messing up something else. You can spin it and try to get oil in there. Good luck.
Old 05-14-2019, 07:36 AM   #4
rocket1
I would take the plug out of the back of the housing,the housing is slightly peened over it.Dig out the dried up grease and relube,I used lubriplate which seemed to work just fine,it might solve your problem.
rocket1 is offline   Reply With Quote
Old 05-14-2019, 08:55 AM   #5
katy
katy's Avatar
Personally, I don't like Lubriplate as it likes to separate, the oil oozes out of the thickener.
Old 05-21-2019, 08:08 PM   #6
papanick
Give that a try but if that dose not work email me and I can service it. [email protected]
papanick is offline   Reply With Quote
