Old 05-11-2019, 06:37 AM   #2
Doug 845
Default Re: 34 won't start?
At this point, I would disconnect the fuel line at the carb to see if fuel is actually getting to the carb when you crank the engine over. If the new pump is doing its job, the problem might be a clogged carb caused by the previous residue in the tank.
Doug 845 is offline   Reply With Quote
